For sale is one (1) SB23MFCL45-4 (4 ohm version) subwoofer driver that was purchased Feb 2019. It's in excellent condition and has less than 10 hours of average use and will be supplied in the original packing at AU$75 plus postage. The DCR has been measured and is right on specification indicating no shorts or open circuits.
Full technical details of this driver can be found at SB Acoustics where a PDF can be downloaded:
8'' SB23MFCL45-4 :: SB Acoustics
The build quality of this driver is exceptional as one would expect from SB Acoustics. As this is a lowish 87.5dB SPL subwoofer driver, it requires a amplifier with high gain and due to low impedance and low Cms, it requires an amplifier with high 4 ohm stable power and high current capabilities.
This is suited to small vented box designs between 20 - 22 litres which gives and F3 between 32-34Hz and even though it's a 8" subwoofer driver, it will out perform many larger subwoofer drivers.
Australia buyers only and shipping would be via Australia Post. Please note that is also listed on ebay oz.
