A few years ago I designed a solid state headphone amp for my Grado's, but I've always wanted to try my hand at a good sounding tube amp for them. The rub is that the Grado's are 32 ohm loads. With my penchant for over-engineering, I decided to use a 6AS7 (6080) tube as an output tube. I use one half of it for each channel, and I'm driving it with a 12AT7 (one half for each channel) which is direct coupled to the 6080. I'm using a bit of feedback around the amp to lower the output impedance a bit more and decrease distortion. The really sleazy part is the power supply. I'm using a telema toroid from digikey (all the parts are from digikey except the tubes and sockets). The two 7 volt secondaries form the heater supply, for the 3 amps of heater current needed, and one of the pair of primary windings is used for the b+. Nothing special about the power supply, it's a several stage RC filtered full wave rectified supply.
The downside to OTL amps like this is that the headphones are driven through a big (electrolytic) capacitor. The other downside is efficiency, if the input (wall) power is compared to the power delivered to the headphones (at clipping) the amp is about 0.05% efficient.
But it does sound quite good.
Here's a picture...
http://www.quadesl.com/madisound/tube_headphone_amp.jpg
Sheldon
Here's a picture...
Sheldon
Ack, a PCB! And to add insult to injury you used a 12AT7, the worst of the 12A_7 series, even worse I'm told than the absolutely horrible 12AU7!!!!!!! How the heck can it sound good!?!?
Hehe glad you like it. Now put a case over that ugly PCB
BTW you forgot that it's not power consumption that matters, but weight. You were supposed to mount that stuff in a 1/2" thick lead chassis.
Tim
Tim
There's exactly what I have to build, except with two tubes so that I can direct couple with the headphones. My headphones are 8ohm so they'll be a good load for a pair of 6as7Gs. I'll have to do mine in a chrome chassis and point to point wiring to boot.
Gotta use enough junk in there to make it look and weigh like a power amp for normal speakers!!!!
- Headphone Systems
- Yet another boring tube headphone amp
