If it was immersed in oil all the time, it might work.
You would need a stable high torque motor. At least needle drag would be a non issue since its swamped by the drag.
My Versa Dynamics TT uses a similiar slightly different approach, hardened steel on a ceramic disc using a special fluorocarbon grease (NYE). No platter wobble and high drag consistancy
Give it a go..,
David
Give it a go..,
David
