I have a lot of caps that I do not expect to use. I bought them from Farnell in 2015 and 2016 and they are brand new and have never been used.
I have listed them below, including Farnell item #, Farnell description, Manuf. prod. # and Qty available.
2504495
CAP, ALU ELEC, 680UF, 420V, RAD CAN SMD; Product Range:LXS Series; Capacitance:680 F; Capacitance Tolerance: 20%; Voltage Rating:420V; Diameter:35mm; ESR:-; Height:50mm; Lead Spacing:10mm; Lifetime @ 66Y9609
ELXS421VSN681MA50S
x10
2504451
CAP, ALU ELEC, 560UF, 420V, RAD CAN SMD; Product Range:KMS Series; Capacitance:560 F; Capacitance Tolerance: 20%; Voltage Rating:420V; Diameter:35mm; ESR:-; Height:45mm; Lead Spacing:10mm; Lifetime @ 66Y9569
EKMS421VSN561MA45S
x10
2504454
CAP, ALU ELEC, 220UF, 420V, RAD CAN SMD; Product Range:KMT Series; Capacitance:220 F; Capacitance Tolerance: 20%; Voltage Rating:420V; Diameter:22mm; ESR:-; Height:50mm; Lead Spacing:10mm; Lifetime @ 66Y9572
EKMT421VSN221MP50S
x20
2504455
CAP, ALU ELEC, 330UF, 420V, RAD CAN SMD; Product Range:KMT Series; Capacitance:330 F; Capacitance Tolerance: 20%; Voltage Rating:420V; Diameter:25.4mm; ESR:-; Height:50mm; Lead Spacing:10mm; Lifetime 66Y9573
EKMT421VSN331MQ50S
x20
2504456
CAP, ALU ELEC, 470UF, 420V, RAD CAN SMD; Product Range:KMT Series; Capacitance:470 F; Capacitance Tolerance: 20%; Voltage Rating:420V; Diameter:30mm; ESR:-; Height:50mm; Lead Spacing:10mm; Lifetime @ 66Y9574
EKMT421VSN471MR50S
x20
2504457
CAP, ALU ELEC, 680UF, 420V, RAD CAN SMD; Product Range:KMT Series; Capacitance:680 F; Capacitance Tolerance: 20%; Voltage Rating:420V; Diameter:35mm; ESR:-; Height:50mm; Lead Spacing:10mm; Lifetime @ 66Y9575
EKMT421VSN681MA50S
x20
2504466
CAP, ALU ELEC, 330UF, 420V, RAD CAN SMD; Product Range:KMW Series; Capacitance:330 F; Capacitance Tolerance: 20%; Voltage Rating:420V; Diameter:22mm; ESR:-; Height:50mm; Lead Spacing:10mm; Lifetime @ 66Y9583
EKMW421VSN331MP50S
x10
2504468
CAP, ALU ELEC, 560UF, 420V, RAD CAN SMD; Product Range:KMW Series; Capacitance:560 F; Capacitance Tolerance: 20%; Voltage Rating:420V; Diameter:30mm; ESR:-; Height:45mm; Lead Spacing:10mm; Lifetime @ 66Y9585
EKMW421VSN561MR45S
x10
2504469
CAP, ALU ELEC, 680UF, 420V, RAD CAN SMD; Product Range:KMW Series; Capacitance:680 F; Capacitance Tolerance: 20%; Voltage Rating:420V; Diameter:35mm; ESR:-; Height:40mm; Lead Spacing:10mm; Lifetime @ 66Y9586
EKMW421VSN681MA40S
x10
2504482
CAPACITOR, ALU ELEC, 39UF, 420V, RADIAL; Product Range:KXJ Series; Capacitance:39 F; Capacitance Tolerance: 20%; Voltage Rating:420V; Diameter:10mm; Capacitor Terminals:Radial Leaded; Packaging:Each; 66Y9598
EKXJ421ELL390MJ50S
x20
2504483
CAPACITOR, ALU ELEC, 68UF, 420V, RADIAL; Product Range:KXJ Series; Capacitance:68 F; Capacitance Tolerance: 20%; Voltage Rating:420V; Diameter:12.5mm; Capacitor Terminals:Radial Leaded; Packaging:Eac 66Y9599
EKXJ421ELL680MK50S
x20
2504479
CAPACITOR, ALU ELEC, 100UF, 420V, RADIAL; Product Range:KXJ Series; Capacitance:100 F; Capacitance Tolerance: 20%; Voltage Rating:420V; Diameter:14.5mm; Capacitor Terminals:Radial Leaded; Packaging:E 66Y9595
EKXJ421ELL101MU50S
x20
2504480
CAPACITOR, ALU ELEC, 120UF, 420V, RADIAL; Product Range:KXJ Series; Capacitance:120 F; Capacitance Tolerance: 20%; Voltage Rating:420V; Diameter:16mm; Capacitor Terminals:Radial Leaded; Packaging:Eac 66Y9596
EKXJ421ELL121ML50S
x20
2504481
CAPACITOR, ALU ELEC, 150UF, 420V, RADIAL; Product Range:KXJ Series; Capacitance:150 F; Capacitance Tolerance: 20%; Voltage Rating:420V; Diameter:18mm; Capacitor Terminals:Radial Leaded; Packaging:Eac 66Y9597
EKXJ421ELL151MM50S
x20
Datasheets and photo's attached. Only 10 files can be attached, so the rest in the next post.
Make me an offer. No minimum quantity. Buy 1, buy 10, buy 100 or buy the lot
Shipping via Australia Post or buyer's preferred method. Pickup for local's (Brisbane area).
Thanks for reading.
Albert
2504495
ELXS421VSN681MA50S
x10
2504451
EKMS421VSN561MA45S
x10
2504454
EKMT421VSN221MP50S
x20
2504455
EKMT421VSN331MQ50S
x20
2504456
EKMT421VSN471MR50S
x20
2504457
EKMT421VSN681MA50S
x20
2504466
EKMW421VSN331MP50S
x10
2504468
EKMW421VSN561MR45S
x10
2504469
EKMW421VSN681MA40S
x10
2504482
EKXJ421ELL390MJ50S
x20
2504483
EKXJ421ELL680MK50S
x20
2504479
EKXJ421ELL101MU50S
x20
2504480
EKXJ421ELL121ML50S
x20
2504481
EKXJ421ELL151MM50S
x20
Thanks for reading.
Albert
Additional photo's and datasheets:
