Chip (gainclone?) type headphone amp
Joined 2003
I’m thinking about building op amp headphones amp and really lost in the variety of option. I would like to build a reasonably simple amp if it will provide good quality sound.
What changes should I make to use gainclone as headphones amp?
Should I put limiter as
http://headwize2.powerpill.org/projects/showproj.php?file=limiter_prj.htm
Or do nothing to amp and use this advice:
http://db.audioasylum.com/cgi/m.pl?forum=general&n=43237&highlight=headphone+amp+diy&r=&session=
Which op amp will sound better in this application LM3875? Or LM1875 is better because it lower power chip? After reading posts on this board I’ve got impression what they provide some kind of magic if used correctly. Or even ad825 will be sufficient to drive sennheisers cans and sound better? Or ad825 with buffer?
What kind of buffer is reasonably simple? Some thing like
http://headwize2.powerpill.org/projects/showproj.php?file=eaton_prj.htm
Or just bite the bullet and go for
http://headwize2.powerpill.org/projects/showproj.php?file=pellerano_prj.htm
if I want really good quality amp.
Any ideas will be appreciated.
Vlad.
GC chips are not generally intended or designed to drive headphones so I wouldn't recommend any of the options you mentioned. The insertion of a limiter would only corrupt the sound and bring no improvement whatsoever. Limiters are used in extreme situations in which it is necessary to protect ears from excessive sound pressure.
No experience with AD chips.
I'd suggest you built a decent A-class amp with FETs or tubes. Headwize site is great and you can find several such projects there. BTW, I've built a preamp-phone amp based on "The Morgan Jones Mini Tube Headphone Amplifier" project. I've been using AKG240 headphones and I'm very pleased with the sound.
Your choice depends greatly on what impedance your headphones are, and the usual stuff like how much do you want to spend, how big a cabinet, etc.
600-ohm phones sound great driven by an opamp like the OPA2134 (i.e. the "Cmoy" amp). 32-ohm phones need an amp with more oomph.
General consensus on headwize, I believe, was that the chip amp (gainclone) amps were too noisy for headphones. Not sure if true or not. I have an LM1875 amp, with a resistor limiter, driving Senn HD580s and they sound fine.
moamps, I'm not sure how a resistor limiter "corrupts" the sound. Are you referring to the headphone impedance variations with frequency, and resulting frequency response changes from adding a resistor?
Hey Paul
I did not know your headphone amp was an 1875 based one. Where are the plans from? What value inline resistor is at the output? I got the Senn 433 phones only to find that they have lousy reviews universally. Oh well .... they are what I could afford. My Gainclone pics are still in the film camera so nothing to post yet but it looks and sounds great...I think. Also another speaker project done with Minimus 7s up top(>500Hz High passed with 22uF) and reflex boxed Radio Shack 40-1197s running full range down below. I don't know how well balanced it is for the technical purist but it sounds good to me.
Greg
A very nice IC headphone amp appeared in May 2003 'Audio Express', by Klaus Noll.
It uses AD744/AD811 line stage (op-amp + buffer) with Jung/Didden regulators.
PCB layouts are provided, along with what I presume to be where to get hold of them.
I would tend to agree with moamps that the GC has too much power gain for headphones.
-- John
Hey,
GainMONEY** and all the gainclones are all opamp based amplifiers, right?
That makes Chu Moy's amplifier at HeadWize ... a small gainclone.
Which makes me admit that I do use a small gainclone to drive my headphones. I use THS4022 though. This thing drives my K240M very well.
LM1875 will fry the poor headphones. Headphones can just berely handle 250mW. Or, your ears get busted. Either one would look very bad. ...
T
** I am quoting from Rod Elliot.
Did connect my Senn 600 to my GC without any limiter.A little bit noisy but the sound was great - really gets the bass down.I would be quite happy listening to it permanently like this , maybe add a switch between speakers and 'phones. The OPA 627 output of my DAC sounds pretty good but I think this was more satisfying.
Re: Hey Paul
Hey, Greg. I have a composite amp, uses a FET opamp driving the LM1875. It was in my living room for years, I repackaged it to place beside my PC. I use it to drive my ELF1.5s or headphones. For the latter, I just used 330-ohm resistors in series. My HD580s are 300-ohm phones. I'm in the middle of changing the power supply for it, I was getting too much hummmmm.
The design was from a Popular Electronics article, probably at least 10 years ago. I'll show you it next time we get together.
Depends, depends. I don't think I can drive even 250 mW into my phones with the impedance levels and the power supply voltage I'm using. But yes, I could damage my ears. That's why I have a volume control.
I replied to Vlad's post about the insertion of voltage (input signal) limiter at his amp's input because he referred to an article on that subject. The insertion of a current limiting resistor at the output doesn't seem to be a particularly good idea either, IMHO (for the reasons you mentioned in your question, among other things). If the resistor is to be inserted, however, I don't think its value should exceed 1/10 of the nominal impedance of your headphones, based on my own experience.
The sound, and what we prefer, is what it all comes down to in the end.
I believe one of the headphone amp projects I've seen actually has two outputs, one with and one without limiting resistors. I can't remember if the author uses the different outputs for different headphones or different types of music...
This could depend very much on the type of headphone. I use Grado SR-60, and they sounded fantastic driven by the current output of a TDA1541a DAC. So I conclude that headphones can sound good driven by a very much higher impedance than the headphones' nominal impedance.
Hey Paulb,
Nice to hear from you once again. :nod:
Was the feedback taken before or after the current limmiting resistor? Do you agree that the LM1875 functions in class A in your application, and could this be a argument in favour of power-opamps for headphone use?
Regards,
Thijs
Regards,
Thijs
Hi Thijs.
Feedback was taken before the resistor - don't forget I used this for both speakers and headphones (just used a switch to turn off the speakers).
The intent of the resistor is not so much current limiting as voltage dropping. Taking feedback afterwards would work against this, and just drop your headroom, so I wouldn't recommend it.
The LM1875 does not operate in Class A, except at very low power levels. Maybe these low levels would apply to headphone use (probably without the resistor). I know others have reported good results from the LM1875 driving headphones; maybe this is why. I think the main argument against chip power amps for headphones were the noise levels.
My thinking exactly... a dedicated headphone amp for low impedance Grado's with power opamps..
The LM3886 has a Iq of about 25mA (guessing a little from the datasheet) and a minimum gain of 10x for stable operation. So if feedback was taken after a 330 Ohm resistor, the Grado would be voltage driven (Low output imp) while still protected for overdrive and the LM3886 would function stable as a follower in class A. Remenber that a Grado only needs 150mV rms realistic SPL levels. This would (about) equal a Log potmeter volume control set at 12o'clock driving this baby from a CD player. Voltage offset would become a major issue.. hmmmmmmm ..
Another idea... take the 330 Ohm to the other side (first the headphone, then the 330 Ohm resistor to ground and take the feedback after the headphone: now it's current driven right? How about making it adjustable .. Rod Elliot has written something like that... hmmmm
I think I will give the first option a try...Peter .. are your reading this? How do you feel about this idea?
Regards,
Thijs
Joined 2003
Thanks for the replays. I’ve got more questions. Could it benefit from regulated power supply? If yes what kind is acceptable? Or it doesn’t mater? Should I use output capacitors? I ask these questions because I was able to find only one parts supply store in my area – rat shack.
Vlad.
