Ah revisit of my curved planar magnetic tweeter (bit to much curve though)
Well i replaced the foil since i dont like Kapton, and i forgot i used Kapton.. see if i can raise the top end a little since thats in this case because of the curve the first to go and give it another try. Please keep in mind this is recorded with in ear mics so use a headphones for correct spatial sounds etc.
At least this project is not dead.
I play one tune Anette Askvik - Liberty go here if you want to skip the rambling TUNE
hello wrine
the ribbon should work vertically. Many horn speakers are also built incorrectly in this regard. Well, yes, you probably know that yourself. Nevertheless, the ribbon sounds very clean. Your videos are very exciting, even though I barely understand the language.
Greetings
Greetings
