ELEKIT TU-8800 SET AMP
Available Now....
TU-8800 $1185 (stock version)
TU-8800 $1,785 (Lundahl Version)
Takman REX50G 2% Carbon Resistor (85 PCS) $65.00
Mundorf Supreme Silver Gold 0.01 X 2 + 0.1 X 2 $150
Gold Lion - Matched Pair KT88 X 2 + 12AT7/B739 X 2 $185
TKD 2CP601S $65
The Lundhal + PCB + HV + Hardware is $645
https://www.diyaudio.com/forums/elekit/353407-inexpensive-tube-set-tu-8800-a.html#post6177418
● Rated output: 12.5W + 12.5W (KT88-HIGH mode / UL connection THD 10%)
● Rated input: 360mV
● Residual noise: 90μV (IHF-A)
● Frequency characteristics: 12Hz to 55kHz (-3dB)
● Input impedance: 50kΩ
● Output impedance: 4 to 6.3Ω, 8 to 16Ω (switched by the switch on the back)
● Input terminal: LINE x 2 (LINE1, LINE2): RCA jack 3.5mm stereo mini jack (uses both LINE2 and cuts LINE2 when plugged in)
● Output terminal: Speaker output terminal: Gold-plated screw terminal (banana plug can be used) Headphone terminal: 6.3mm headphone jack
● Power supply voltage: AC120 / 200V 50 / 60Hz (3P inlet)
● Power consumption: 95W
● Body dimensions: W350 x H204 x D324mm (including protrusions)
● Body weight: approx. 12kg (without power cord)
IT SHOULD BE 7581 (NOT 7591)
OPTION: Lundahl OPT
I'm waiting for this to be released, especially with the Lundall transformer upgrades. I have a TU-8200 I built years ago and it just doesn't have quite enough oomph for my liking. This looks much like a TU-8200 on steroids.
@vkung - Is there a list I can get on to order one as soon as they're available?
Error on label?
Victor,
I think there might be an error on the tube label, see attached. The 7591 (circled in red) is not pin compatible with the other tubes. Shouldn't this be 7581?
Regards, Steve
With all due respect
to you and especially Mr. Fujita, the 7591 has a different pin-out than almost all other power tubes. Plugging a 7591 into an amp that's stet up for 6V6, 6L6, EL34 etc. could do damage. See the attached basing diagrams.
With regards, Steve
